I'm sure this has been asked a billion times, but...........
Novice 8N Owner
03-23-2001 08:13:22
..... what grade of gas will my 8N like the best? I have been told regular unleaded is fine. Others have to me use an additive(Marvel Oil?). What do you all think?
N8NO
9N'er.
03-24-2001 11:33:35
 Re: I'm sure this has been asked a billion times, but........... in reply to Novice 8N Owner, 03-23-2001 08:13:22
I added Marvel MO to the gas, and I suspect, that caused additional fouling than just my mediocre rings or valves. If you are burning some oil already (if not GREAT), I wouldn't add the Marvel to it. I find the N and 850 run best on the cheapest gas with low octane and lead. Sort of like drinking Coors Light...it runs good on the cheap stuff, but the last thing we need is Coors Light blowby and rapid succession backfire; that is the absolute worst thing to experience...
BrianJ
03-23-2001 11:54:53
Just use the cheap gas. The N will work on 70 octane because of the low compression. Lead isn't needed because of the hardened valve seats, besides you don't want your children to be exposed to the lead.
rob 8N11071 KS
03-23-2001 08:16:10
Buy the cheapest unleaded you can find, and put the money you save into something else to make your tractor happy, like more frequent oil changes or hydraulic fluid changes.
Amen! (ED)
03-23-2001 09:07:32
 Re: Re: I'm sure this has been asked a billion times, but........... in reply to rob 8N11071 KS , 03-23-2001 08:16:10
good advice - and don't waste money on lead additives
