NAA in the snow
Rusty VT.
02-28-2005 11:45:46
NAA, filled tires with chains ... I've been tempted to try to use it to break a trail through the sugar woods.
Anyone think that I'd have any luck driving this over snow (not plowed, not blowed, not even packed down ... just a couple of feet of snow)? How much would it take to get stuck?
Jimmyjack
02-28-2005 18:29:34
 Re: NAA in the snow in reply to Rusty VT. , 02-28-2005 11:45:46
I have an NAA with loaded tires and chains and use it winters in the woods. I am in Northern Wisconsin, and the winters vary, but it will take a quite a drift before you get bogged down. Once the trail is broken, and freezes down, you will have it made. It also depends on the texture of the snow. (sugar snow spins tires easier) Steering is the toughest in deep snow, and a touch on the rear brakes might be needed. I have 3 sets of chains and the deeper the snow the bigger the links. I dont think you will have too much problems for the most part.
Upper Peninsula, Mi
02-28-2005 17:16:13
Rusty. If you felt confident that the tractor could handle it, you wouldn't have asked the forum, right? If you had a front mounted plow, like the one I posted today in the Tractor Photos, you may have a chance. Look for 1940 9N with Dearborn snow plow. My email is open. Good luck and have fun with the sugar bush. Ron
Erik Graham
02-28-2005 15:16:01
I have a NAA with loaded tires and no chains (on the list for next winter) and would have to agree with the other posters. At the moment you lose traction your tractor will start digging down and it will continue to do so until it hits something it can bite into. If that happens to be at axle depth, well.....
Cheers,Erik
Scott-IA
02-28-2005 13:57:45
Are you kidding me? Fluid AND chains? I doubt you'd ever get it stuck on good timber ground as long as it's fairly flat. Stay out of the ditches.....at least anything more than ankle deep and have fun!
Fessman
02-28-2005 13:28:16
Once it starts to float up on the snow, you will get stuck. That is once the undercarriage gets hung-up. If you can wait until the snow packs down, you will have much better luck. I try to pack it down with the snowmobile if the snow starts to get too deep. That combined with a little thaw, and refreeze and it is great to travel on.
Fessman
BillM (OH)
02-28-2005 13:04:21
If you can keep the rear wheels in contact with the ground, it'll work -- but I'd bring a shovel along if I were you. My brother and I used to run a contest every spring -- winner was the first one to get through the barway where it always drifted. Used to hit it in high gear WOT -- always wound up shoveling her back down to the ground!!! With the snowpack underneath the belly, you could turn the wheels with your fingers..... . Good luck!!!
duey
02-28-2005 12:58:30
Go FORTH... send back pictures! Bring your snowshoes with in case ya don't make it back in the seat!
How about skis on the front and half-tracks on the back?? They had N's down to the South Pole, right?? Send pictures!! duey
duey
02-28-2005 19:01:59
 duey again in reply to duey, 02-28-2005 12:58:30
Dad used to say, tongue in cheek, that an Oliver on steel wheels would go through so much snow it"d push you off the seat...!!!! :-))
Steve IA
02-28-2005 12:56:23
Only 1 way to find out. Let us know how far you got when you get back. 8^) Steve NAA III443
