Order Ford 8N Parts Online
48/49 8N
Ron H. Watson
03-01-2005 11:39:37
Won't Start. Arc is blue from plugs, New carb. cannot detect fuel on plugs when choked. Please help. Thanks
Jimmy D
03-01-2005 17:36:11
 Re: 48/49 8N in reply to Ron H. Watson, 03-01-2005 11:39:37
Pull the plug on the bottom of the carb float chamber to make sure the float chamber is full of fuel. If it doesn't flow fairly well, you likely have at least 1 of 3 filters restricted. Check and post back.
Ron Watson
03-06-2005 14:52:16
 Re: 48/49 8N in reply to Jimmy D, 03-01-2005 17:36:11
Jimmy, I have good flow from the bottom of the carb. I put new plugs in and the engine hurried up like it was trying to turn over but it never did. Thanks for the help.
souNdguy
03-01-2005 11:55:43
Are you getting fuel thru the carb? Check at bowl drain.
Try starting on ether. if it starts on ether but dies.. think fuel delivery.
If it started on ether and then runs.. check for a vacume leak at the carb to manifold gasket.
post back.
Soundguy
