Stabilizer bars, how to attach?
Ron(IND)
03-23-2001 14:05:00
I got stablizer bars that attach to the draw bar and attach to the bracket under the fender mount. my question is how do they attach to the bracket under the fender? Thanks for all the help I get from you guys. Ron
Ed Gooding (VA)
03-24-2001 04:08:10
 Re: stabilizer bars, how to attach? in reply to Ron(IND), 03-23-2001 14:05:00
Hi Ron: See if this picture will answer it for you:
third party image
Regards..... ..... Ed
'52 8N475798
Ron(IND)
03-24-2001 05:09:34
 Re: Re: stabilizer bars, how to attach? in reply to Ed Gooding (VA), 03-24-2001 04:08:10
Ed, That answered my question perfectly. Thanks. I've never seen item #4 before. What manual did this pic come from? Ron
Ed Gooding (VA)
03-24-2001 05:16:02
 Re: Re: Re: stabilizer bars, how to attach? in reply to Ron(IND), 03-24-2001 05:09:34
This picture is from a parts and accessories catalog for N tractors that I have.
Part#4 is a key part in order to attach the stabilizer bar to the fender bracket. Original Dearborn part# is 230044
'52 8N475798
Dave 50 8N
03-23-2001 15:13:47
The brackets under the axel have to be on right. I forget which side the "L" foot hangs down on. Close to the wheel or center? Perhaps someone has a pix? Hopefully, you have several holes in your bracket to adjust the length.
The end of the bar at the implement flairs to the outside.
Scott(Ks.)
03-23-2001 15:39:36
 Re: Re: stabilizer bars, how to attach? in reply to Dave 50 8N, 03-23-2001 15:13:47
Like Dave says. There is a slight flair on the ends of your sway bars. The bend in go's toward the tractor and the bend out go's at the implement. The easy way to put them on is to install the end under the axle first then barely raise the implement off the ground without lynch pins in the implement. Gently swing implement back and forth to line up the sway bars and install lynch pins. SAFETY FIRST, keep your feet out from under and watch out for PTO. Don't raise the implement but just enough to clear the ground.
Pitch
03-23-2001 14:47:16
Mine has pins on the bottom of the fender mounting bracket with holes through them for lynch pins.
ED
03-23-2001 14:16:25
There are separate L shaped brackets that get bolted on the underside of the fender mounting bolts.
Mine had four holes each to best match the location of the lower arm pivots on the differential housing.
A set of bolt thru pins attach the bars to the brakets.
