Plow Size????
poppey
03-01-2005 17:22:06
How do you measure a plow to get the "bottom size"? Or should I say where do you measure? Rookie
poppey
03-02-2005 16:24:43
 Re: Plow Size???? in reply to poppey, 03-01-2005 17:22:06
Thank You everybody!!! I now know that I own a 14" two bottom plow. You guys are really helpfull.It's great to have this web sight.
Ultradog MN
03-02-2005 13:47:40
third party image
Good luck
Jerry
Scott-IA
03-02-2005 09:10:34
You can measure from plow beam to plow beam to figure that out. It's the ammount of ground each bottom is responsible for. From shin to shin horizontally. If you can use the plow frame it's the easiest. If not, from one shin to a line directly forward of the next....you get the idea. :)
Ron/PA
03-02-2005 09:10:02
Measure the distance between the beams. Be sure to measure like sides of the beams. Ron
Jeb2N
03-01-2005 18:03:02
I could be mistaken as i'm not a plow expert, but I beleive that the distance is the horizontal measurement between the bottoms, say, from the flat edge of the frog on one bottom to the same point on the next bottom. These are usually 12, 14, or 16" measurements with 12 and 14 being common.
