Toolbox before cleaning picture
James41-9n
03-05-2005 22:06:49
third party image
here is the toolbox before I started cleaning it. The picture doesnt really show how bad the rust and crud were.
James41-9n
03-06-2005 14:36:02
 Where do I get OSPHO stuff? in reply to James41-9n, 03-05-2005 22:06:49
HOOKER
03-05-2005 22:45:26
 Re: Toolbox before cleaning picture in reply to James41-9n, 03-05-2005 22:06:49
whats the latest on the sherman shifter lever or have ya decided yet????
the tool box looks great, as for the inside???
dremel makes a good tool thats has a scotchbright type pad that goes on it
jake
James41-9n
03-06-2005 07:38:37
 Re: Toolbox before cleaning picture in reply to HOOKER, 03-05-2005 22:45:26
The Sherman may still be bent a little, but first I am going to mount a 3 (or 4) x 6 braket and try to raise the tool box 2-3 inches to see if it clears the shifter. I dont want to get it too high but I dont need to get in and out of the toolbox all the time, though I do want to get a set of the basic tools that came with the tractor, I think it was a furrow wrench and a pliers, maybe anything with a Script Ford Logo from eBay just to go inside for the period.
The inside is cleaned up also, but needs some Dremel work in the tight spaces, gotta do it right.
James41-9n
03-05-2005 22:08:50
 Re: Toolbox after cleaning picture in reply to James41-9n, 03-05-2005 22:06:49
third party image
Here is the toolbox after I electrocuted it for about 20 hours, then hit it with the wire wheel. I still need to clean the inside of the box out as I cant get the wire wheel inside to do a proper job.
Next comes the prime and paint. I will post a picture then also.
Thanks for your hints and helps everyone.
Fessman
03-06-2005 05:22:36
 Re: Toolbox after cleaning picture in reply to James41-9n, 03-05-2005 22:08:50
James,
Nice job!! I'm going to have to get myself set-up for the "electro" job. Did you take a pic just after it came out of the electro bath??
Fessman
Benjamin
03-06-2005 06:59:21
 Re: Toolbox after cleaning picture in reply to Fessman, 03-06-2005 05:22:36
nice! I use a chemical called "ospho" to kill rust, when in the end leaves a clear primer base for paint to adhere too. I dont have any long term results to report, but I do know its used in marine industry (on the water) and everyeone I've talked to seems to use and like the stuff!
good luck
the box looks great!
Ben
Carl in Vermont
03-06-2005 08:21:24
 Re: Toolbox after cleaning picture in reply to Benjamin, 03-06-2005 06:59:21
I used Ospho on Model A fenders and bodies 35 years ago and the paint hasn't shown any problems yet. I am prepared to wait.....to see if it is really good....
