abjahnke
03-08-2005 00:59:29
Re: Pull start only in reply to Bruce (VA), 03-07-2005 16:35:16
i commented on this the other day, but i dont think it took. i also agree, get rid of the 8v battery, rewire the whole thing, battery to the generator, coil, very good thickbattery cables,and a very thick cable from starter to starter button. they carry more power, and less loss of current along the way. then go to a place like a farm ,tractor-implement shop and or NAPA Auto where you can pick up wiring. you dont need a wiring harness, just follow the old route or read the manual for your tractor. also get rid of the old resistor and put a new one in. just do as much work on it as you can afford at a time. but start at the battery. and roll on. once your finished , you will know whats been done, and done right. have a continuity tester, and digital multimeter. these will help , and for additional help the best manual is the IandT service manual. its very easily understood, the rest can be found in this site in the forums , and an excellent bunch of people that are willing to help with your questions, as long as you give them the respect they deserve. My tractor is is good running wonderfully, and i am doing most of the work, with the help of others on site , so there is no excuse for not learning here, other than not wanting to learn. Its really fun and the satisfaction a person gets from doing his own work. next thing you will get into gas and oil, and the three point hitch. good luck, and thanks all . abjahnke
