Order Ford 8N Parts Online
8N Head replacement nuts
Roughstock
03-11-2005 17:02:49
I was going to put my head back on tomorrow but the original nuts are in bad shape. Is there a substitute I can get or do I need the original replacements? Napa had some #8 nuts that would fit but they are not as deep as the original. What do you think
Dan
03-11-2005 17:50:30
 Re: 8N Head replacement nuts in reply to Roughstock, 03-11-2005 17:02:49
Here in Dallas we are blessed with a store called Elliotts Hardware. They have two full isles of fasteners, roll pins, studs, woodruff keys, hardened dowel pins, c-clips - you name it. They carry grade 5 and grade 8 bolts of all sizes and in fine and course threads AND a full line of 7/16" bolts in both grades. The old man that works that department is VERY knowledgable in that area and knows me pretty well by now. I go in about 2 times a week getting new bolts. Almost every bolt, nut, washer, stud, etc. on Project Rustbucket has been replaced and the ONLY bolt I could not find was the darn clutch pressure plate to flywheel bolt. So I ended up using a grade 8 bolt the same size without the shoulder.
Point is, find your "Elliotts" and it will serve you well.
Good luck,
Dan
Kelly Jewell
03-11-2005 17:37:55
Roughstock, I had a machine shop build my 39 9N engine last year and I asked Chuck to come up with some new tall 7/16" sae nuts and locktite them to the studs with 1 and 1/2 threads showing. The next day Chuck called and said he was using nuts from a big block Chevy main bearing stud kit. They look great...thanks, Kelly.
s1120
03-12-2005 03:05:26
 Re: 8N Head replacement nuts in reply to Kelly Jewell, 03-11-2005 17:37:55
There's a company that makes all kind of hardware for the HP, and auto restore hobby. The name is ARP. Not sure if they have a web site, but I have used there stuff on many motor projects, and it is A#1 stuff!!! Search it out, I assume they can get what you need.
Paul B
Roughstock
03-11-2005 17:44:39
I'll check that out, Very interesting!
don b
03-12-2005 06:00:30
 Re: 8N Head replacement nuts in reply to Roughstock, 03-11-2005 17:44:39
I know where the correct nuts are available, email me if interested. don b
HOOKER
03-11-2005 17:35:38
if ya gotta ACE hardware near they have all the studs and nuts you'll ever need in grade 8 fine thread or you could always do it the redneck way and getta tap to chase the threads and a angle grinder to true up or nearly true up the sides of the nuts
jake
Roughstock
03-11-2005 17:41:18
 Re: 8N Head replacement nuts in reply to HOOKER, 03-11-2005 17:35:38
I have a true value in town so I'll go over tomorrow befor they close. Just wanted to make sure the depth difference was ok. Thanks.
