Order Ford 8N Parts Online
8N almost back together and run's
Roughstock
03-12-2005 17:08:29
I got my new cam gear on and reinstalled the head,manifold,Radiator,and front cover. I had my buddy hold a funnel that I rigged to the fuel line and I filled it up with fuel to test the engine since I didn't have the hood on. It started right up and seems to run Good.I had 45lb's of oil pressure at full throttle and 39 at idle. Amps were a little hay wire until I found I had put the jump wire on the wrong top prong on the altenator. I'm going to try to get it all back together tomorrow and drive it. Thanks for all the help!!!
Jimmy D
03-12-2005 18:12:29
 Re: 8N almost back together and run's in reply to Roughstock, 03-12-2005 17:08:29
Great news and congrats on the success!
Roughstock
03-12-2005 18:24:45
 Re: 8N almost back together and run's in reply to Jimmy D, 03-12-2005 18:12:29
I was starting to worry about you, Haven't heard from you. Incase you didn't see the postings I've been leaving my tapping noise was coming from my fiber cam gear. The center hub was loose and shifting back and forth. I replaced it with an aluminum gear.Thanks again for all your help and don't be a stranger.
Jimmy D
03-13-2005 06:05:43
 Re: 8N almost back together and run's in reply to Roughstock, 03-12-2005 18:24:45
Good to hear that solved the issue for you, knew you would get it. Appologies for being absent. I had a bad spell of luck and have been pretty busy with repairs on a couple of vehicles and some plumbing issues that almost drove me batty.
Roughstock
03-13-2005 06:10:03
 Re: 8N almost back together and run's in reply to Jimmy D, 03-13-2005 06:05:43
Sorry to hear that but I'm sure a vehicle problem is nothing for a man of your knowledge. Now the plumbing well its just one of those nasty things that has to be done. Good luck to ya!
HOOKER
03-12-2005 17:27:46
glad to hear its going, sounds like great oil pressure too..
jake
