8 volt battery in a jubilee with 6 volt system
bill/va
03-12-2005 18:21:54
can you use a 8 volt battery in a jubilee with a 6 volt system???
bill
Russ in SoCal
03-12-2005 18:50:16
 Sure ya can. . . . . in reply to bill/va, 03-12-2005 18:21:54
. . . but I would suggest doing an archive search for "8 Volt."
Russ
Kelly Jewell (KY)
03-12-2005 18:35:58
 Re: 8 volt battery in a jubilee with 6 volt system in reply to bill/va, 03-12-2005 18:21:54
Bill, sounds like your 53 is hard to start. Most of the time the starter is bad. The max amps your 6volt starter should draw is 150 amps. I have a meter I've loaned to several customers and they come back and say your meter goes to 600 amps and my starter maxed it out. If your 6Volt battery is say 585 cold cranking amp and your starter is pulling close to that, there is not enough left for the distributor. I've never talkied to anyone that was happy with the 8Volt battery in a Ford tractor. I have new starters if you need one....thanks, Kelly.
