Old Warrior Steering Gear Wacky - pic
Ramrod
03-13-2005 12:51:03
third party image
I finally got around to assembling the tie rods on my NAA, and the front end is way outta alignment. I may have a sector gear off by a tooth, and I would appreciate it if y'all would take a look at the pics and see if you can help me figure out which gear may be off, or if it's just way outta alignment. Click below to see the pictures, and thanks!
ZANE
03-13-2005 16:11:10
 Re: Old Warrior Steering Gear Wacky - pic in reply to Ramrod, 03-13-2005 12:51:03
count the turns from full right to full left. Then turn the steering wheel from stop to half way point. The pitman arms should both be pointing back the same amount.
From your picures it seems that the left pitman arm is one notch off toward the front.
Zane
Russ in SoCal
03-13-2005 14:08:51
Ramrod,
You are aware that the drag links for left and right are different lengths? Looks like it could be a tooth off on the left. Both should have a slightly aft position at nuetral.
Russ
P.S. Don"t ask about the different lengths.
