Pic of my new jubilee (and at least 1 question)
Paul in VA
03-25-2001 16:35:20
third party image
Drove the Jubilee home this afternoon. There won't be much rust as it has been well protected with paint. So much paint that I could not read the gear selectors and drove it several miles in 1st gear, then the rest of the way home in 3rd. Fortunately I was able to make all but a few hundred yards via back roads.
First question: The seller said the vane type hydraulic pump had been replaced by the newer type. Does the photo agree with this?
Mike OH
03-26-2001 07:56:16
 Re: pic of my new jubilee (and at least 1 question) in reply to Paul in VA, 03-25-2001 16:35:20
Paul -Congrats on getting the Jubilee. Sheet metal looks good and looks like you even have a toolbox under the left running board. Don't find too many that aren't rusted out. You definately have a piston type pump. Where does the hydraulic line coming from your lift cover go. I haven't seen a set-up like this before. Best of luck - I know you'll really enjoy your tractor once you become acquainted. Be sure to get an I&T FO-19 manual for her and give her a name.
Paul in VA
03-26-2001 15:21:15
 Re: Re: pic of my new jubilee (and at least 1 question) in reply to Mike OH, 03-26-2001 07:56:16
Mike...That hydraulic line just ends. Probably was to a front end loader or something?
Thanks for identifying that it is indeed an upgraded pump.
As you can see by the photos, she is well protected with paint...lots of it. I have worse problems to deal with, like rims to replace and steering sector to check and probably replace on Dad's 2N, get the 640 running and finding out why there seems to be no battery charging, why the oil pressure is so high & where the coolant is going on this one. (Tractor doesn't overheat, got a proper pressure cap for her today...hope that's all that's wrong there...the old one had no rubber seal).
Paul
Paul in VA
03-25-2001 16:38:09
third party image
Another picture (the other side). What does the range lever tell about the transmission type?
Paul in VA
03-25-2001 17:06:10
 Re: Re: pic of my new jubilee (and at least 1 question) in reply to Paul in VA, 03-25-2001 16:38:09
Okay, if it's an under/over/direct Sherman, should it work a rototiller in low?
Thanks,
Paul
no......Dell (WA)
03-25-2001 23:27:25
 Re: Re: Re: pic of my new jubilee (and at least 1 question) in reply to Paul in VA, 03-25-2001 17:06:10
Paul..... ..unfortunately, the 3-speed "Sherman" aux tranny in low gear slows down the PTO too. The only "cure" is the rare and fragle "Howard" aux tranny which mounts between the tranny and the differential gear. N-Tractor are really not a rototillering machine but they are an excellent 2-bottom plowing machine..... ..Dell
Paul in VA
03-25-2001 17:23:17
Think I just found the answer to my own question at Link . Looks like the pto also gets slowed down, so maybe it's not gonna work (unless I regear a tiller).
RICKWI
03-25-2001 16:58:13
Thats a Sherman lever, looks same as over-under-direct. It has two positions for over-under then in center should pull out and pivot for direct. If you had it in under and trans in low you wouldn't be home yet.
Gaspump
03-25-2001 16:57:50
The lever is of the type that is often connected to a over-under-direct Sherman.
