Disc harrow size
Arn
03-15-2005 14:45:25
My '50 8N has been completely rebuilt, including very healthy hydraulics. Is a 6-1/2 foot angle-frame disc harrow asking a little too much out of the machine? I'd be working fairly soft soil (no clay). I think the disc weight is something like 540-550 pounds. Tractor easily lifts a 60-inch Woods mower or loaded 30" scoop. Thanks.
Dell (WA)
03-15-2005 16:43:13
 Re: Disc harrow size in reply to Arn, 03-15-2005 14:45:25
Arn..... ...yer tractor hydraulics should lift about 750#. Yer 6-1/2 3-point disc harrow should work just fine behind yer 8N. You may need added tractor tire weight for traction, but try it ennyways and iff'n it cutts too deep, just lift yer hydraulics a littlebitt and run with yer little "flush" handle in horizontal "draft" mode..... .....Dell
2fordsmike
03-15-2005 18:21:35
 Re: Disc harrow size in reply to Dell (WA), 03-15-2005 16:43:13
We had a 7-foot tandem Dearborn purchased new and used in the 1950s, and it was a full load for an 8N and was about perfect behind a Jubilee. The perfect tandem for an 8N would be a 6-foot in medium soils. As Dell says, you should get along fine.Mike-Iowa
