Order Ford 9N Parts Online
9N sure seals
Ratchet
03-15-2005 18:20:42
Ok I was reading bout these sure seals for my 9N. How the blazes do ya get hem on. I beveled the edges like i read in old posts. Seems when I get one side in the other pops out. Advice sure would be appreciated.
Moons 2N
03-16-2005 06:26:59
 Re: 9N sure seals in reply to Ratchet, 03-15-2005 18:20:42
It wouldn't hurt to buy a spare when trying to do this. (I didn't). Like the others have said, grind a little off, then whacking them in with a pvc pipe. They will go in, but you really have to be patient.
Charlie in MO
03-15-2005 21:24:36
Try using a wire wheel bench grinder to polish the leading edge of the seal about 1/8". The wire wheel will polish off some of the sealer on the outside of the seal. Lay the seal against the opening and hold a flat piece of wood against the seal... Whack the board with a healthy hammer. It should start the seal. After you get it started, have a look and Whack it on whichever side it needs to straighten and drive it flush. Good luck. Charlie
Kelly Jewell (KY)
03-15-2005 20:05:43
Ratchet, did you pack the axle brg good with grease? You know the SS92 sure seal will prevent rear end lube from oiling the bearing....thanks, Kelly.
Tom in MS
03-15-2005 19:04:40
I took pliers and was not easy to do but I slightly bent the lead edge in a little all the way arounf to help get them started. Also I applied grease to the edge all the way around. Still I would think I had it started then it would pop out on the other side..They will eventually go..They seem to be a milligillionth oversized..
Drmeatman
03-15-2005 18:36:40
Ratchet,If you've tried several times to press them in you may have the "cup" burred. Check.I took a peice of PVC of the same size to use as a drift.Placed a peice of 2x4 on top and used a "big" maul and gave it a big smack.Worked for me.
