Carb rebuild
Rick(Ont)
03-25-2001 22:01:53
I need to rebuild my carb, and printed out the excellent article from this site by Don Stewart. My problem? I can't even get started! The 4 screws holding the upper and lower halves together are frozen. I can't budge them without damaging them. Any suggestions?
Thanks, Rick
Salmoneye
03-26-2001 05:33:43
 Re: Carb rebuild in reply to Rick(Ont), 03-25-2001 22:01:53
Gentle, flameless heat may help.
If it is sunny and warm where you are, place the whole carb on the hood of a dark coloured vehicle and try the screws again.
I don't recommend torches around carbs.
Soaking the whole thing overnight in carb cleaner might help too...
TimK
03-26-2001 08:15:33
 Re: Re: Carb rebuild in reply to Salmoneye, 03-26-2001 05:33:43
Whatever you do, don't pound, because you'll crack the carb. The screws that hold the two halves aren't that odd or scarce, so after the soaking etc. like the other post says, a small pair of vise grips or perhaps drilling out the screws probably will be your only answers.
