Barnstormer
03-19-2005 10:30:28
Re: Getting stuck in reply to Pooh Bear, 03-19-2005 02:49:17
Tractors and stuck seem to be a universally contagious condition. Anyone who says "never" I don't believe. I've been stuck so many times I would like to apply for the world record. (my wife and kids will testify to it) Each time can be different circumstances and require a different solution. My wife says stay out of the mud! Phooey! If stuck with a 3 point implememt, unhook if you don't have another vehicle to pull you. You can't plow while your stuck. I've frequently drove out and then used a chain to pull the plow out backwards to higher ground. Dig, dig, dig, dig, dig, dig...by hand. Clear the dirt from in front, rear and under the tractor. Put planks or old tires down for the rear tires to climb onto. And, once moving, don't stop until you are out. BUT, don't spin the wheels especially if you aren't moving! If you have another tractor, as you said, you still need a driver on the stuck tractor. Unless you have a very powerful pulling tractor, you can't "dead pull" a stuck tractor. Believe me! Been there, done that (14 years old). Lastly, once you are out, quickly wash the tractor, don't tell your wife, and go do something else. grin
