Order Ford 9N Parts Online
Need a starter relay/switch for 9N
Roughstock
03-19-2005 16:43:52
I thought I would try one last time befor converting the starter switch. I need the switch or relay that bolts on the engine side of the steering housing. When you push the starter button a shaft pushes thrue to the inside and pushes this switch. It has two terminals one goes to the starter and the other to the bat. Anybody know where I can get one? THANKS I belive this tractor is about a 1941 9N I cant find any #'S.
( Pic ) Ken N Tx
03-19-2005 18:39:48
 Re: Need a starter relay/switch for 9N in reply to Roughstock, 03-19-2005 16:43:52
Are you in Texasthird party image
third party image
Roughstock
03-19-2005 19:03:56
 Re: Need a starter relay/switch for 9N in reply to ( Pic ) Ken N Tx, 03-19-2005 18:39:48
No I'm in OKLAHOMA. I'll look tomorrow and try to clean that spot up for the #. THANKS
Jimmy D
03-19-2005 17:06:38
Hey Rough, accordin to my book, the switch part number is 9N11450B, the FO4 manual shows it on page 123, Figure 182, item number 1. Pretty sure you could pick that up from FNH or even the sponsor of this fine board.
old9
03-19-2005 19:11:01
 Re: Need a starter relay/switch for 9N in reply to Jimmy D, 03-19-2005 17:06:38
I bought one from New Holland several years go. It worked fine ,but didnot look stock .Was $ 32.46 then. Lots of Luck joe
Jimmy D
03-19-2005 19:17:51
 Re: Need a starter relay/switch for 9N in reply to old9, 03-19-2005 19:11:01
I looked and found one from the sponsores of this board. The price was just under $11 cheap.
Roughstock
03-19-2005 19:36:16
 Re: Need a starter relay/switch for 9N in reply to Jimmy D, 03-19-2005 19:17:51
Thanks for looking it up but I think the one TONY S gave me at trustytractor.com is identical to the original. But it is expensive. The cost is $43 dollars after shipping. Thanks for the part # it was the same # on trusty tractor I don't think they would have known what I meant when I orderd a starter switchy thingy.
