Order Ford 8N Parts Online
remote hydraulic valve for 8n/9n on e-bay
robert mangus
03-20-2005 09:29:11
third party image
Hi,
I found this remote valve on e-bay cheap. Will it fit an 8 or a 9N??
thanks for the help
Robert in Oklahoma city
Dell (WA)
03-20-2005 09:44:14
 Re: remote hydraulic valve for 8n/9n on e-bay in reply to robert mangus, 03-20-2005 09:29:11
Robert..... ..NO, I doubt it.
While there is a trick to by-pass the internal hydraulic pump by chaining down the 3-point lift arms and forcing the hydraulic power to come out the corner pressure relief valve pressure test port. That slide-action valve won't bolt over the corner pressure relief port.
There is also another way to internally modify the hydraulic pressure tube between the bottom pump and the top-cover hydraulic lift control with a lever operated valve that sticks up thru a hollow topcover bolt. It still makes the hydraulic power come out the corner hydraulic pressure test port.
Bottomline, ain't fer 8N/9N's, won't fit nuttin..... ....Dell
