Light switch fuse
BURNZEE
03-26-2001 08:23:17
Hope this isn't to stupid of a question. What size of fuse do you use in the headlight switch? I have an 8N that has been converted to 12 volts. Thanks
Dr.C,Mo.
03-26-2001 12:19:57
 Re: light switch fuse in reply to BURNZEE, 03-26-2001 08:23:17
Your question causes me to ask a dumb question.
Where is the light fuse on a 2N 6-volt?
TimK
03-26-2001 21:23:18
 Re: Re: light switch fuse in reply to Dr.C,Mo., 03-26-2001 12:19:57
On the 2n, the light fuse is on metal clips which are connected directly to the light switch where the wires are connected. A number of tractor models have the same set up, or so I have seen.
Don (NC)
03-26-2001 13:13:12
The only ones I've seen were in-line fuse holders behind the light switch.
Claus
03-26-2001 09:27:51
Go with a 20 amp Slow Blow. This will give you a little extra and will not burn out the wires in case of a short to ground.
Happy Motoring
Claus
BURNZEE
03-26-2001 11:15:04
 Re: Re: light switch fuse in reply to Claus, 03-26-2001 09:27:51
Thanks Claus. The only bad part of fixing my headlights is that I won't have an excuss this summer for not getting the place mowed. Not even darkness.
