Starter won't disengage
rob 8N11071 KS
03-26-2001 09:12:22
My starter turns and starts the tractor just fine, but it keeps spinning. My first guess was a failing starter, but I've read through the archives and it looks like this could also be three things:
- bendix mechanically stuck in engaged position
- low battery juice
- bad solenoid
any other ideas?
gary
03-27-2001 17:26:07
 Re: starter won't disengage in reply to rob 8N11071 KS, 03-26-2001 09:12:22
You probably have it fixed for now but if the starter keeps spinning then some thing and not the bendix is keeping the magnetic coil energized maybe even a bad starter switch. Just a thought good luck
Gary
03-26-2001 21:21:37
My neighbor has a 8n and his kept spinning, he said he beat on the solenoid or relay depending on what school your from, until it stopped. O'reilly's carries them.
TimK
03-27-2001 06:49:27
 Re: Re: starter won't disengage in reply to Gary, 03-26-2001 21:21:37
If the starter bendix disengaged because of beating on the solenoid, it's only coincidental. The starter bendix is not an electrical hookup, and disengages only after a certain rpm is reached, unless dirt of damage prevents it.
Dell (WA)
03-26-2001 11:03:50
Rob..... .most solenoid failures are "open circuit" which I discount because you can start your tractor.
Starter drive failure most eazily diagnosted by removing starter and visually inspecting drive. Starter drive must be clean and non-oily to work properly..... ..Dell
