Battery
rick IL
03-21-2005 18:42:42
Why is my battery draining in my 8N. Battery is new. Yes it's hooked up right. Positive ground. Any thoughts?
HOOKER
03-21-2005 19:23:11
 Re: Battery in reply to rick IL, 03-21-2005 18:42:42
read closely,,
take a test light- the kind with a bulb in the handle, wire and clip on one end,, sharp point on the other
pull the positive side off the battery and connect the clip to it,, now stick the sharp end on the battery terminal if it lights,, you got battery voltage going somewhere, hook your battery back up and start tracing with your test light finding what lights it up when your key is off jake
ZANE
03-21-2005 18:52:52
Could be a number of things but most probably it is the cutout in the voltage regulator sticking.
After the engine has been shut down for half an hour lay you hand on the generator. If it is still warm to the touch that is probably the problem.
Zane
