Order Ford 8N Parts Online
8n head gasket
noviceRLP
03-22-2005 01:38:59
I recently purchashed an 8n that had leak around one of the center head gasket bolts, I cleaned the head and replaced the head gasket. It still leaks around the same bolt. Am I missing something? The head was within .003.
Lennich
03-22-2005 09:43:23
 Re: 8n head gasket in reply to noviceRLP, 03-22-2005 01:38:59
Yup you missed it .. Pull the head bolt put some gasket sealing material on it to seal the threads and you will be OK.
jiminoystercreek
03-22-2005 02:16:18
What was leaking? Coolant or combustion gases. Did you check the flatness of the block deck?
If its coolant, you might be able to use a sealant on the head bolt thread. Combustion gases, I'd use something like an Indian Head gasket sealant. Hope this helps and good luck!
noviceRLP
03-22-2005 12:30:21
 Re: 8n head gasket in reply to jiminoystercreek, 03-22-2005 02:16:18
Thanks, i"ll go try tat now
