Need NAA Differential Expert
Ramrod
03-22-2005 07:11:14
What's up with the pinion gear thrust washers? I can only find used parts, and like one of my thrust washers, they all seem to have a ridge on the inside and fit tightly on the spider shaft, but look good otherwise. It looks to me like these guys should float on the spider shaft, because the inside of the washer is etched & grooved to allow oil and the outside is smooth. Could I simply enlarge the hole on the ridged washers to allow them to fit better on the NAA spider shaft and use them?
Ramrod
