O.T. Jiminoystercreek
Richard H.
03-22-2005 12:34:17
As Dell said touching the breakers will give you a good clue to what"s loaded to the max. You and I have the same problem when it comes to campground survival, we have one to in this family. An Amprobe is a better tool I believe to see who is using what and how much if there seems to be a problem. Where your at you probably need to look at the worst case scenario just knowing the temps are gonna soar and all a.c. units are on plus microwaves,water heaters and on and on..... Lot"s of no-lox on all connections and tight lugs. Make a drawing of your sites to try and make sure the distribution is right using the 80% rule. Nobody likes an unhappy camper! Mohawk Campground, Ind.
