starts/quits
Tums
03-22-2005 14:53:02
Hi, I have a 8n that starts fine and runs good but quits after 30 minutes and won't start till it cools down, any ideas?
Ramrod
03-22-2005 16:27:23
 Re: starts/quits in reply to Tums, 03-22-2005 14:53:02
Don't forget to check for proper venting of the gas cap.
Ramrod
Dave H (NY)
03-22-2005 15:41:51
Try jumping out your key switch (if it is the original Ford type) when it quits if it re-starts you know you need to change the switch. Change the condenser even if it's new it could be bad. Lastly check your coil, a visual inspection will tell alot if it's overheating it will have what appears to be tar dripping down it, if so change it for a new one of the correct voltage, if you have been converted to 12 volts get a 12 volt replacement. Good luck post back with what you find.
Tums
03-22-2005 16:07:03
 Re: starts/quits in reply to Dave H (NY), 03-22-2005 15:41:51
I have heard of the bad switch deal, I'll try that tomorrow if it quits.
Thanks Tums
Rob
03-22-2005 15:10:50
 Check this out from the archives. in reply to Tums, 03-22-2005 14:53:02
Maybe you don"t have a front-mount distributor, you didn"t say.
Anyway, check out the link.
