NAA Votage Regulator - NOT Tisco
Dan
03-23-2005 13:25:21
Can anyone help me locate a good American Made voltage regulator for a 6 volt B circuit NAA tractor - NOS Ford Tractor part would be ideal. All the ones I keep finding are made in India (Tisco, Tractor Supply, etc.), and the two I have bought both make my ammeter bounce. No luck at the NAPA parts counter, their book said "N/A" under 54 Ford Tractor Regulator. No luck on a Google Internet search either. Anyone ever locate a good one? I don't mind spending a little extra for a good quality regulator.
TIA,
Dan
Ramrod
03-23-2005 13:56:46
 Re: NAA Votage Regulator - NOT Tisco in reply to Dan, 03-23-2005 13:25:21
CNH p/n FAG10505A
Landmark - 32.28
McMaster - 29.59
LM can get one for you, McM will have them in Friday or Monday, just sold the last one today.
Ramrod
Dan
03-23-2005 14:07:06
 Re: NAA Votage Regulator - NOT Tisco in reply to Ramrod, 03-23-2005 13:56:46
You sure keep up with McMasters stocked items! Do you have a VPN connection directly to their inventory system?
Or, was it YOU that took the last one? :)
Thanks,
Dan
Ramrod
03-23-2005 14:19:14
 Re: NAA Votage Regulator - NOT Tisco in reply to Dan, 03-23-2005 14:07:06
I'm a 12v guy, but I got a couple of well trained CNH parts guys!
Ramrod
Rob
03-23-2005 13:45:33
 I'm curious about that B-circuit regulator. in reply to Dan, 03-23-2005 13:25:21
You have it there to see the wire wound resister? Riveted on the back I imagine. I figure it"s riveted onto the FLD and then the ARM. Can you see that by looking at the backside or do you have to open it up?
Dan
03-23-2005 14:04:07
 Re: I'm curious about that B-circuit regulator. in reply to Rob, 03-23-2005 13:45:33
You just flip the regulator over to the back and you can see this resistor soldered between the FLD and ARM fields.
Dan
Rob
03-23-2005 14:26:11
 Re: I'm curious about that B-circuit regulator. in reply to Dan, 03-23-2005 14:04:07
Thanks, now I know for sure I can tell the difference between the A-circuit and B-circuit regulator. Maybe I"ll still remember if I ever need to.
It"s now in the ytmag archives anyway.
