steering sector thrust washer ?
9n8801
03-25-2005 06:28:21
Good morning to all,I need Help !!!!! ! I need three outer thrust washers PART #9n-3543
for a 1939 Ford Ser.#9n8801.This is the large one.
I have tried all part houses that I know of,But they do not carry them. If you have any used ones,please advise.
Leon in N W Florida
Rob
03-25-2005 12:04:39
 Re: steering sector thrust washer ? in reply to 9n8801, 03-25-2005 06:28:21
Try a bearing house or brake and axle shop and ask about machinery bushings. They come with large ID"s like 1", 1-1/4", 1-3/8", etc and come in different metal gauges.
I have in my hand a 14ga. 1-3/4" bushing that is 2-1/2" OD. You probably need just smaller than that; the 1-3/8" or 1-1/2" maybe. You might find that thrust washer is an off the shelf machy bushing. Those guys might have shims too or hopefully the proper gauge bushing.
OH Boy
03-25-2005 06:41:27
I think I have heard others speak about having to make up what they needed out of shim stock. I don't believe these washers are still available.
If you know how much thicker you need the washer to be, get some shim stock in that thickness, cut a shim and insert it next to the washer that is already in there.
