Front Loader
RustyAL
03-26-2005 14:02:38
Bought a dearborn loader minus the pump and mounting hardware for the front. The N newsletter shows a bracket that mounts with a special axle pin. What are the chances of finding the mounting stuff and pump. The loader is the type with a big gaurd over the grill 19-42 maybe. It is not wore out and has no welds. The hose are all rotted of and it is rusty. All of the cylinders were closed as it set in the woods for many years. The loader has a few fairly large tree parts still attached. So it must have been in the woods a long time. The loader will clean up nicely. Any help is greatly needed.
Tweeter
03-26-2005 14:32:58
 Re: Front Loader in reply to RustyAL, 03-26-2005 14:02:38
I have a Dearborn 19-42 loader too. I am hoping to put it on my 2N. Does yours have the two dump cylinders on the bucket? Mine came with pump and mounting bracket. My mounting bracket slides into the king pin and bolts to the radiator support with two bolts. I have yet to mount it. My loader had a cracks in the booms right behind the dump cylinders on both sides. One was already fixed and I fixed the other side by welding it shut and then added a plate to the underside for support. Cylinders seem good, hoses are ok, no leaks. What are you going to put this loader on?
RustyAL
03-26-2005 14:39:15
 Re: Front Loader in reply to Tweeter, 03-26-2005 14:32:58
Yes, the loader has the dump cylinders. I have not decided what to put it on. The N newsleter mentioned a special mounting kit for 2n, 9n. Since I don,t have the kit the loader will most likely go on a 52 8n. The loader looks real heavy. Any idea how much it weighs.
Tweeter
03-26-2005 15:09:45
 Re: Front Loader in reply to RustyAL, 03-26-2005 14:39:15
I think it weighs 975 pounds. Why will it not fit a 9n or 2n?
RustyAL
03-26-2005 15:35:06
 Re: Front Loader in reply to Tweeter, 03-26-2005 15:09:45
Don't Know. The pamplet says: While the Dearborn Industrial Loader was designed for the model 8N Ford tractor it can easily be adapted to 2n ,9n through the use of a special front suspension plate, sold separately by your Ford Tractor and Dearborn Dealer.
Tweeter
03-26-2005 15:46:31
 Re: Front Loader in reply to RustyAL, 03-26-2005 15:35:06
Is there any way you could email the pamphlet to me? My email is open.
