Clutch Gone?
premie-farmer
03-26-2005 16:08:48
This morning moving the MCCormick Deering No.7 out of the old demolished barn so I could start the rebuild. All of a suddedn the 8N"s clutch didn"t seem to want to work!. It worked fine when I put her in gear to go to the barn but when I pushed it in to drop it in Neutral and turn off the PTO all I got was grrrrr r of the PTO lever and a quick jolt out of reverse. When I hooked up the mower and went to mover out and lift the boom clutch pushed in grrrrr rrr on the PTO lever and first gear. Finally got it reluctantly into 4th and managed to get the mower where I need it and the tractor back in it"s space but still no clutch. Parked and in neutral now. Any ideas? Free play at clutch feels about right.
premie-farmer
03-27-2005 08:12:14
 Re: Clutch Gone? in reply to premie-farmer, 03-26-2005 16:08:48
third party image
Just checked the clutch linkage between showers. All looks ok except the adjsutment screw is about 1/4 in from the top. Hope the pic shows up. Any ideas folks?
premie-farmer
03-27-2005 08:20:23
 Re: Clutch Gone? in reply to premie-farmer, 03-27-2005 08:12:14
Well looks like the picture won't load. It's in the Gallery under parts & pieces 52 8N clutch. I'm thinking that's adjusted awfully high on the screw.
Russ in SoCal
03-27-2005 10:25:28
 Re: Clutch Gone? in reply to premie-farmer, 03-27-2005 08:20:23
pf,
Adjustment looks fine. By freeplay "feels ok" do you mean it is at three-quarters of an inch? As long as you have SOME freeplay, the clutch is engaging as fully as it can. If it was my tractor, I would adjust the freeplay down to maybe half inch and try to get a little more time out of it. BTW, when you checked the linkage, did you watch it as the pedal was depressed and released?
With the right tools, jacks, and a good place to work, a clutch is quality time with yer tractor. With a dirt floor, unlimited headroom and a few sticks of firewood, it can be downright miserable.
Russ
premie-farmer
03-27-2005 15:34:15
 Re: Clutch Gone? in reply to Russ in SoCal, 03-27-2005 10:25:28
Yeah the linkage moved freely in and out and the free play looked to be about 1/2 in for the ruler. As far as splitting goes don"t have a barn anymore since the Ice storm did the roof in would have to do anything on my own in the barn lot and that doesn"t sound like it would be too much fun! I guess I"ll try and adj it down a little and see if that gets me to at least be able to get some post holes dug for the new barn and then get it hauled to the local NH shop to get the clutch repaired. I"ve only had it two years now and it"s been out of commission more than in over that time.
Russ in SoCal
03-26-2005 19:26:12
pf,
Afore ya go draggin it down to the dealer, take a real close look at yer linkage on the left side of the transmission. If a bracket or pin gives way, ya can have the symptoms you describe. Hope that"s all it is.
Russ
HOOKER
03-26-2005 17:07:15
sounds kinda like your pressure plates about gone????
jake
premie-farmer
03-26-2005 17:21:19
 Re: Clutch Gone? in reply to HOOKER, 03-26-2005 17:07:15
Affraid that was the problem seems every spring it"s something new. If it"s time to split it and put a new clutch in her I"ll have to haul it to local NH dealer since I have no shop to do it in. Bet that will cost about $400 or $500.
HOOKER
03-26-2005 17:50:15
 Re: Clutch Gone? in reply to premie-farmer, 03-26-2005 17:21:19
where abouts are ya lokated????
near BROKEN ARROW, OK????
yer right it'll be expensive!!!!
gotta swing set and a rolling jack could save yerself $65.00/hr at the dealership???
jake
premie-farmer
03-26-2005 18:13:50
 Re: Clutch Gone? in reply to HOOKER, 03-26-2005 17:50:15
Nope in KY. Would have to do this outside if I split it myself. Have put plenty of clutches in cars and trucks but always on concrete never on the grass. Plus have notihing to hold up the front and back figures I finally get it starting every time with 1 push of button and something big goes. Oh well so in the life of a tractor huh.
HOOKER
03-26-2005 18:27:42
 Re: Clutch Gone? in reply to premie-farmer, 03-26-2005 18:13:50
2 sheets of 3/4" plywood does great, a concrete block to sure up the front end, and a rolling jack for the tranny part and roll the rearend back a little ways would probably save yerself $300. parts are only about a 100.
i'd almost come and do it fer that
jake
