Order Ford 8N Parts Online
8N Hydraulic Lift
Terry S
03-26-2005 16:43:35
My 8N will only lift half way up, But if you drop the lift arms all the way down to the ground, the lift will lift all the way up and hold. Once you drop the lift arms, they will not raise over half way unless the lift arms are dropped all the way down to the ground. The lift arms usually won"t drop down far enough with an implement installed to raise fully. Any ideas. Thanks, Terry (IN)
Patrick/N-Tiques/OR
03-27-2005 09:12:19
 Re: 8N Hydraulic Lift in reply to Terry S, 03-26-2005 16:43:35
My 861 was doing a similar thing. I bought the gauges and instructions from Zane (he throws in a cam follower pin). Tore it apart yesterday. The cam follower pin was worn down to about 1/8" left on the pin! I reached in to tug on it and it broke off. I do not know what was keeping it together! Put in a new pin, followed his alignment procedure and... Walla! It simply works great!
A couple of weeks ago, I did this to one of my 8Ns... same thing... cam follower pin was worn... not real bad. But, bad enough that a proper operation was elluding me. Used Zane's alignment tools, new pin... great results!
I highly recommend to anyone that has a lift issue to seek out help from Zane.
Patrick
ZANE
03-26-2005 18:35:48
Could be that the cam follower pin/dowel is slipping off the cam when it is trying to raise the lift in position control mode. This condition is usually caused whent the position control mechanism/linkage becomes badly worn and where it pivots has too much wear in it and is letting it push off to the side.
See the link below for a jig and adjusting booklet for the 8N lift
Terry S
03-29-2005 04:01:19
 Re: 8N Hydraulic Lift in reply to ZANE, 03-26-2005 18:35:48
Zane, Come to think of it, my draft control doesn't seem to be working.
HOOKER
03-26-2005 17:24:27
 ZANE!!! yer doorbells a ring'n in reply to Terry S, 03-26-2005 16:43:35
ZANE is one of many knowledgable in hyd.'s
look to the left of yer screen he has many articles to check out, and then you'll see why a lot of us look up to him...
jake
Roughstock
03-26-2005 18:44:55
 No reason HOOKER in reply to HOOKER, 03-26-2005 17:24:27
Did you get the picture of the air cleaner top I sent ya? I was just wondering
HOOKER
03-26-2005 18:53:33
 Re: No reason HOOKER in reply to Roughstock , 03-26-2005 18:44:55
i did now, it wouldn't open earlier,, that would show off a mini jd, as tall as it is you could probably put a small mouth gallon jar on it and catch a whole buncha jd's at once, then ya wouldn't hafta waste precious seat time to empty out the trash
and so far momma's happy
jake
Roughstock
03-26-2005 18:59:34
 Re: No reason HOOKER in reply to HOOKER, 03-26-2005 18:53:33
I'm going to go Monday and take a hole bunch of pictures so you can see if ya think it's worth your while coming down. Just want to make sure because I know how busy you are. And I'm glad Momma's still happy.
