Order Ford 8N Parts Online
1949 8n electical problem side mount dist
rugclnr
03-28-2005 08:19:58
Tractor started misfiring and stalled. Would not restart. No spark. Replaced wiring harness. No spark. Replaced coil. No spark. Replaced wires from dist. to coil. No spark. Grounded red primary from coil to terminal block and got spark. If I ground between open points and dist. case, Iget spark. Is this normal?
rugclnr
03-30-2005 06:57:26
 Re: 1949 8n electical problem side mount dist in reply to rugclnr, 03-28-2005 08:19:58
It started, don't know why did not do anything but check point gap. Weird. Thanks everyone for your suggestions.
Jerry
rugclnr
03-30-2005 06:58:34
 Re: 1949 8n electical problem side mount dist in reply to rugclnr, 03-30-2005 06:57:26
Dell (WA)
03-28-2005 15:01:51
Rugclnr..... ....sounds like yer sidemount distributor thru-the-body insulator is shorting out. Ya replaced yer wiring, good chance for you to muck-up yer insulator. ($3, cheap) Sometimes the flat-spring connector crack/breaks where the points connect and it is hidden under the insulated screw. New points ($3, cheap)..... ..Dell
rugclnr
03-28-2005 15:07:45
 Re: 1949 8n electical problem side mount dist in reply to Dell (WA), 03-28-2005 15:01:51
replaced copper strap and insulater last year.
Dell (WA)
03-28-2005 15:23:21
 Re: 1949 8n electical problem side mount dist in reply to rugclnr, 03-28-2005 15:07:45
rugclnr..... ....SO WHAT?... can still go BAD from hamm-handed shadetree mechanics. INSPECT CAREFULLY..... ..respectfully, Dell
ZANE
03-28-2005 09:03:48
If you are getting spark from the high tension wire coming from the coil when held close to the engine block etc and making contact from the open points to ground either the points are not making up or the points are not closing or the distributor is not turning.
Zane
r
03-28-2005 14:55:51
 Re: 1949 8n electical problem side mount dist in reply to ZANE, 03-28-2005 09:03:48
What do you mean by points making up? The dist. is turning.
