lift
rod hamm
03-30-2005 09:28:24
my hydralic lift will not lift with the back blade on it, without the blade it will. worked fine all winter this is something that just happened. please help
Russ in SoCal
03-30-2005 12:40:38
 Re: lift in reply to rod hamm, 03-30-2005 09:28:24
rod,
Most likely cause of yer symptoms is a bad relief valve. Read through the linked article for an understanding of hydraulic system behavior. Took me a while, but I finally figured out there is no magic involved in the lift operation.
Russ
Rick H. Ga.
03-30-2005 11:15:51
Rod, the simplest and cheapest thing you can do is to change your hydraulic fluid and do a little maintnenace on the lift system; remove the side cover plates after draining fluid and clean out as much of the gunk and gook as possible; put in new 90 wt G-1 mineral oil or Ford/NH 134 oil; try it again. If no results, your problem is more extensive and will require removing the lift cover and/or pump.
HTH (Hope this helps) Rick H. Ga.
