Order Ford 8N Parts Online
8N No Spark
R.A. Shelley
03-30-2005 09:37:15
I have an 8N with a front mount distributor that isn't getting any spark. I converted it to a 12V system and can't get a spark ever since. I have my 12V at the top of my coil when the key is turned on, but still no spark. I think I have a bad coil. However it is brand new. Anything I have overlooked converting it?
Bob
03-30-2005 09:43:14
 Re: 8N No Spark in reply to R.A. Shelley, 03-30-2005 09:37:15
Try stretching out the curly "spring thingy" sticking out of the bottom of the coil a bit, so it makes better contact with the special socket-head brass screw beneath it, in the distributor.
If that doesn't do it, check the point gap, and the little copper strap from the terminal on the points to the terminal previously mentioned that the spring on the coil contacts.
If everything's OK there, it's time to do some serious troubleshooting with the distributor on the bench, using an ohmmeter.
