+ or - Ground
RJL
03-31-2005 17:04:11
Hello Guys I am new to the Ford tractors, I am trying to help a friend get a Ford 2N 9N 8N going I dont know which one it is but it is one of those 3. Anyway I need to know if these tractors are Positive or negative ground. Were any of the later 8Ns Negative ground? Thank You For Your Help!
Rob N Va
03-31-2005 19:08:37
 Re: + or - Ground in reply to RJL, 03-31-2005 17:04:11
Generally speaking, the tractors with the red chassis and white sheet metal are 8N, and the all grey are either 9N or 2N. 9n and 2N tractors had a 3 speed transmission and the 8n has 4 forward speeds and reverse. Give us the serial number and we can identify for you. We can most likely help you troubleshoot the problems and get it running. ---Rob
Drmeatman
03-31-2005 18:16:18
RJL, 9n,2n,8n, all org.6v. + ground !
RJL
03-31-2005 17:16:43
Sorry I Did not Know they were available in 12 Volt. This is an all original tractor and it is 6 Volts. Thank You For the reply
Bob
03-31-2005 17:33:50
 Re: + or - Ground in reply to RJL, 03-31-2005 17:16:43
They WERE NOT originally available in 12 Volt, although many old tractors have been converted to 12 Volts in later years.
Bill in Orono, MN
03-31-2005 17:21:51
If 6 volt it is most likely a + ground.
MNGB
03-31-2005 18:28:12
 Re: + or - Ground in reply to Bill in Orono, MN, 03-31-2005 17:21:51
Not all 6 volters are positive ground I changed mine to negitive ground 20+ years ago, and now changed it to a 6 volt alternator.
GB
Bill in Orono, MN
03-31-2005 17:07:04
6V or 12 volt??
