Order Ford 8N Parts Online
8N tool box
Roughstock
04-01-2005 11:27:32
I have an original tool box to put on my tractor and don't know exactly where it goes. I have seen them on the battery box and the finder and I know it was probably a dealer add on so where do you think it would go? Its the small box that is sloped on the back side.
Barnstormer
04-01-2005 11:34:24
 Re: 8N tool box in reply to Roughstock, 04-01-2005 11:27:32
There whould be a bolt hole directly behind the battery in the dash support channel. There should also be one on the top of the battery box channel (right side of tractor). Corresponding holes in the tool box should line up with these holes when the box is sitting against the support, behind the battery. hth
Roughstock
04-02-2005 17:34:22
 Re: 8N tool box in reply to Barnstormer, 04-01-2005 11:34:24
I found the holes and the box fit like a glove!! THANKS
Russ in SoCal
04-01-2005 13:15:21
The tool box with which I replaced the tool box without a battery box bolt hole was a tool box with a battery box bolt hole.
Russ
