O.T. Pond question
ratropia
04-03-2005 11:28:54
My 8n and me dug out a 25 X 20 X 4 hole for a pond. I have read about other ponds that n owners have dug, and would like some "if I can do it again I would?" advice, before I go further. And the dirt is HARD clay. Will I need a liner or not? It will be an ornamental pond with some fish. Thanks for the input. Rick T
RussMO
04-03-2005 15:42:13
 Re: O.T. Pond question in reply to ratropia, 04-03-2005 11:28:54
Put in a liner for that size of pond. It solves several problems later i.e. leaking, weeds, etc...
Lennich
04-03-2005 15:39:42
I had a pond like this ,,it is what we call a sky pond,, no source of water.. if this is true line it . If you have a source of water (constant,like a spring )it will be ok as is. Just smooth it out and try to pack it hard.
Roughstock
04-03-2005 15:10:10
How did you dig it?
ratropia
04-03-2005 16:17:44
 Re: O.T. Pond question in reply to Roughstock, 04-03-2005 15:10:10
8N and a Ford slip scoop. It took 5 hours and a little hurt back. I used a single bottom plow to "loosen" the earth first then had to again to loosen the clay. I want to post a pic but cannot seem to. I did get one posted on the community album under pond.
Thanks for all the replies thus far.
Rick T.
old
04-03-2005 12:09:40
If you didn't hit any gravel in the clay you will probably be ok with out a liner. Drive your tractor in and out of it a little to pack it down and add water and see what happens. If you find you have a small leak get a few ducks and they will slowly seal it
ratropia
04-03-2005 11:32:45
third party image
pic of hole for pond
Pooh Bear
04-03-2005 16:45:36
 Re: O.T. Pond question in reply to ratropia, 04-03-2005 11:32:45
third party image
ratropia
04-03-2005 16:47:24
 Re: O.T. Pond question in reply to Pooh Bear, 04-03-2005 16:45:36
How did you do that?
