Order Ford 8N Parts Online
Thinking on buying a 8n
SBM
03-28-2001 06:49:02
I have been looking into a 8n,when the tractor is started the oil pressure is above 50,and after running a good while it drops to 20...Is this right or am I looking at repair bills right away if I purchase this tractor?
Rod
03-28-2001 19:15:05
 Re: thinking on buying a 8n in reply to SBM, 03-28-2001 06:49:02
My 52 8N stays at 40-50 but I use 30w. I've read that those that use 10W30, the pressure drops when oil gets hot.
Ken N Tx
03-28-2001 14:13:18
Cold oil is thicker and higher pressure, warm oil is thinner and lower pressure...
8nTN
03-28-2001 10:03:51
Mine is 50 at start up and 15-20 when warm. From what I gather (archives) this is acceptable.
Brent D
03-28-2001 09:06:00
Sounds good to me - and normal.
Mine starts out ~40 cold and drops to ~10 when good and hot. I wish it was 20 - but 10 has been working fine for 2 years now.
Brent
2fordsmike...No, no, no, this hobby too addictive
03-28-2001 08:12:55
SBM: You don't want this or any other Ford tractor. They will lure you and tempt you. You will dream of them at night. You will work on them all day. Get bruises and strains yanking wrenches in salvage yards, and get sunburn working on them in your own yard. If you get one, you will want two. If you have two, you will want four. A Ford tractor will change your life forever. Mike-Iowa
ED
03-28-2001 07:05:10
Is it 20 at idle or at full throttle?
My '46 2N runs between 30 and 40 with throttle above 1/2.
SBM
03-28-2001 08:52:57
 Re: Re: thinking on buying a 8n in reply to ED , 03-28-2001 07:05:10
You know for the life of me I do not know.I will have to check it out when I get off from work and get home.I will do this and post back this afternoon.Thank you,I am not the sharpest tack in the box.
bj/8N/mt
03-28-2001 10:07:07
 Re: Re: Re: thinking on buying a 8n in reply to SBM, 03-28-2001 08:52:57
while you are checking look for play in the steering and in the rear hubs on the axels--also make sure the hubs haven't been welded. also try the hydralic lift to make sure it lifts a man on the arms and stays up at least a few minutes with the power off
any of those is a five hundred dollar add on to the budget
