main wiring-2n
paul-mo
04-03-2005 19:51:58
I am replacing the main wiring assembly on my 2n. do you need to take the hood off to do this.also any easy way to run the wires through the tube from the dash to gen.
Dell (WA)
04-03-2005 23:02:55
 Re: main wiring-2n in reply to paul-mo, 04-03-2005 19:51:58
Paul..... ....pends how nimble yer fingers are wheather you want to take yer hood off. And you need a helper to handle the awkwardness of the 120# flexable hood/doglegs/empty fueltank over the radiator cap and foward over the trippy frontaxle to setter down on a sawhorse. Your call.
As for fishing yer new 1-terminal coil wire and 1-terminal genny wire down the sparkie tube. I cutt the OLD WIRES and tie them to the NEW wires and with a spritz of silicon spray, pull them foward thru the sparkie tube to the front of the engine. Simple, eh? ..... ....Dell
