Strange part #??????
Roughstock
04-05-2005 15:51:29
I have two original matching Hubs that I belive came off of a 2N but the part # is BUDD9N1106A3
and one has a date on it 2-6-46 and the other is 2-8-46. What is the BUDD on the part # and I would belive they came off a 1946 or 1947 ? I am going to sell them and I want them to be described properly because they are like new and I would want them to get there full glory.and also they both have two little flat bumps Rectangle in shape and about an inch long that stick up on each side of the center close to were the rim sets and the other hubs I have do not, any idea why? Thanks!!
Bob McWhorter
04-06-2005 09:40:28
 Re: Strange part #?????? in reply to Roughstock, 04-05-2005 15:51:29
You have described 2N hubs. The two bosses are stricly identifying features. Ford found that steel wheels were breaking hubs, so you will find the reinforced design has not only the idenifying bosses, but also five ribs vs. three.
Roughstock
04-06-2005 16:55:53
 Re: Strange part #?????? in reply to Bob McWhorter, 04-06-2005 09:40:28
Thanks for everyone's help
Charles (in GA)
04-05-2005 20:11:36
Hubs, drums, discs, etc are generally something a manufacturer farms out to a supplier. Budd is a huge supplier of wheels in the truck industry, along with other parts. These could be original, in fact, most likely are.
I have a '70 mustang. I've owned it since it had 19,000 miles on it. The original brakes are all marked KH (Kelsey-Hayes) except for one rear brake, on which all parts are marked Wagner-Lockheed (drums, backing plates, cylinders) I know all parts were original when I acquired the car in '71, the factory simply mixed the parts (all identical and interchangeable) in production.
Charles
HOOKER
04-05-2005 18:43:02
after that post i gotta check mine out tomorrow
"" HOW CHIEF THROBBINGFINGER ""
is that budd from yer personal cache of parts across town
jake
kelsh
04-05-2005 18:30:14
ThyssenKrupp Budd Company is located in Troy Michigan and they make all types of castings and automotive parts. They were formaly known as Budd Wheel Company in Detroit Michigan.
Tom Evans
04-05-2005 18:23:59
Budd made wheels,railroad cars, cabs for C series Ford trucks and lots more...
Roughstock
04-05-2005 18:48:15
 Re: Strange part #?????? in reply to Tom Evans, 04-05-2005 18:23:59
Thanks for the info. So do you think they came on the tractor original or aftermarket.
Crockett
04-05-2005 17:07:14
Rough:
Not sure if this will help or confuse the issue. Today I replaced a set of rear brake drums (original) on a 1990 Dodge 3/4 ton 4WD. Those drums too had a BUDD stamp on them. My guess is that your N and my Dodge are not the only drums w/ that mark. Best guess would be some type of manufacture mark or a quality control mark. Someone smarter than me will fill us in. Good question!
Crockett
04-05-2005 17:17:52
 Re: Strange part #?????? in reply to Crockett, 04-05-2005 17:07:14
Rough:
Your post made me curious. A quick Google search shows a BUDD company out of MI which makes products (drums and discs) for the auto industry. Makes sense for my Dodge. Not sure how early they started but they must have made your hubs. HTH!
Roughstock
04-05-2005 17:55:25
 Re: Strange part #?????? in reply to Crockett, 04-05-2005 17:17:52
Makes me wonder if some of the work was contracted out by ford or Like Jeb said they were early original aftermarket?
Roughstock
04-05-2005 16:02:24
 Re: Strange part #??????MORE INFO in reply to Roughstock, 04-05-2005 15:51:29
In case someone dosn't know because I didn't say.
They are front hubs.
Jeb2N
04-05-2005 16:13:45
 Re: Strange part #??????MORE INFO in reply to Roughstock, 04-05-2005 16:02:24
I have also noticed the two rectangular bosses on the hubs. My only guess is a possible casting pour location or vent hole? As for the "BUDD" part, i have no idea. Possibly original replacement parts offered by another company?
Jeb
