Brand New Plugs Bad
2Ndizzy
04-06-2005 17:53:04
Throught with Champion plugs. Just tuned my 2N with everything new down the line from Resister to distributor components. Developed a skip that was driving me crazy. Checked everything down the list. Thought I had a bad wire, bad cap, bad valve, bad everything. Everything was pointing towards #1 cyl. Finally pulled plug and temp replaced it with one of the old ones and the enging ran fine. These were new plugs. Out with Champion and bact to Autolite.
rodgernbama
04-07-2005 14:05:21
 Re: Brand New Plugs Bad in reply to 2Ndizzy, 04-06-2005 17:53:04
I also put champions in my 8n and it ran rough after awhile. They did'nt have many hours of running on them. I switched to Autolite. I think they are a better plug.
clearfield
04-07-2005 07:48:58
At my Ford dealership over the years we have had alot of trouble with Ford running on Champion plugs our service dept gets calls from Ford owners
wanting to know why there vehicle runs so bad after it was tuned up at a local independant garage
the first thing we ask them what type plugs did they put in 99 percent of the time they say Champion we tell them thats your problem most people do not believe us but for some reason Ford just do not run right with champions you need to use Autolite or Motorcraft.
clearfield
dbNga
04-07-2005 06:19:29
I had a bad experience whith Champion plugs over ten years ago in a lawnmower. I would not buy another one unless it was the only one on the shelf and the clock was ticking...then I would buy several because I have found them to be inferior to anything else and know they will fail you. Champion may have been recommended 50+ years ago but they are not what they use to be.
Jimmyjack
04-07-2005 06:13:15
Local auto-parts store carries them, but says they are the worst plug he carries. Foul them once and they are done.
HOOKER
04-06-2005 19:01:51
try NGK 3112
i like'm
henry ford would roll in his grave but whatever works the best "" I'M THERE""
jake
Roughstock
04-06-2005 19:22:11
 Re: Brand New Plugs Bad Hello HOOKER in reply to HOOKER, 04-06-2005 19:01:51
Glad you showed up,me helping some of these guys is like a doctor doing surgery while reading the instruction book! Ken
HOOKER
04-06-2005 19:28:07
 Re: Brand New Plugs Bad Hello HOOKER in reply to Roughstock, 04-06-2005 19:22:11
thats not always a bad thang!!!!
i wish i had a book tonight when working on a NH tc45d had to rebuild an injector pump from memory and very few parts the guy had in his storage building,,
check yer mail
jake
TennesseeMan
04-06-2005 18:29:22
Same thing happen to me on a 1952 Chevy truck I had. I was stumped as to why my truck ran so terrible after the tune-up. Go figure.
Hobo,NC
04-06-2005 18:06:24
Zackly what I said 35 years ago
