Leakin' Guv'ner
8ngreenhorn
04-09-2005 13:31:50
How much oil should be leaking from my governor before I start a worryin'?
JohnMD
04-09-2005 14:24:39
 Re: Leakin' Guv'ner in reply to 8ngreenhorn, 04-09-2005 13:31:50
A lot of governors leak because they are warped due to uneven tighting of the bolts. It leaks to much when it bugs you. Replace the gasket and use some blue RTV and it will stop. Remember, short bolt on top.
Stickler
04-09-2005 14:03:39
Ideally none should leak. I just replaced the balls in mine on the 2N the other day. Id had a winter's worth of grunge all over it from a slow weep. Now it don't leak a drop. I did have a bit of trouble getting it to seat though. Mine only has one set screw in the center piece instead of two, and it didn't set right the first time. Took it off and made sure it was right and not a drop now. Used a new gasket.
