clutch
pete hall
04-10-2005 17:13:35
is there a setting for the fingers on the pressure plate that ride against the throwout bearing?
pete hall
04-12-2005 05:35:42
 Re: clutch in reply to pete hall, 04-10-2005 17:13:35
I made the tool,thanks for the info,ive never seen this info in any manuals!thanks
Rob
04-10-2005 17:28:43
Yes. The fingers need to be 2" off the surface of the flywheel.
RobinPA
04-11-2005 09:08:30
 Re: clutch in reply to Rob, 04-10-2005 17:28:43
I made that tool using that diagram when rebuilding my 8N and installing new clutch. It worked really well. Actually saw it sitting in the garage just the other day I had forgotten about it.
Rob
04-11-2005 09:17:12
 Re: clutch in reply to RobinPA, 04-11-2005 09:08:30
It"s the right tool for the job and you need to set the forks. I measure some other way using a 12" straight-edge. Can"t remember exactly how but with a little math, it was not all that hard to get it set-up without the tool. That tool would make it a no-brainer.
