Exhaust Clamp
Pitch
04-10-2005 17:39:33
Bought a new TSC muffler today Actually made in USA. How does the clamp go? Wide side to manifold narrow to pipe or vice versa?
Bruce (VA)
04-10-2005 17:55:42
 Re: Exhaust Clamp in reply to Pitch, 04-10-2005 17:39:33
Yep, big side down, like Rob sez. Don't forget to use Never-Sieze on the nuts. And, inspect the flange on the exhaust pipe; a little dent or kink, and it will leak!
Rob
04-10-2005 17:48:54
Narrow on the manifold. There"s a trick to get the pipe tight in the clamp. You assemble it just short of snug and then hold up on the clamp as you tighten the bolts. It needs to be up around that smooth part of the manifold. If you do that the clamp with pull everything together, lift the pipe up hard against the joint, and pull itself down snug and the joint will not be floppy.
Do it right and that joint is rock steady and will not leak.
Pitch
04-10-2005 18:37:01
 Re: Exhaust Clamp in reply to Rob, 04-10-2005 17:48:54
OK Thanks guys. Really didn't need a new exhaust untill yesterday when I hung the muffler on a branch in the woods and it pulled bent and deformed the flange end.
Pitch
04-10-2005 18:36:51
HOOKER
04-10-2005 18:46:38
 Re: Exhaust Clamp in reply to Pitch, 04-10-2005 18:36:51
been there done that before!!!!! !!
ya might try an up-flow exhaust
thats my new deal,, cuz anything ya hit with it will sure let ya know whenit slaps in the face and dam_ near off the seat, rednecks don't let that happen twice
jake
