AUX HYDRULICS
PJ LONGHORN
04-12-2005 17:24:35
HOW CAN YOU PUT AUX HYDRULICS ON A 1953 8n. CAN YOU PLUM INTO THE DRAIN PLUG ON THE BOTTOM RIGHT SIDE OF THE TRACTOR AND PUT A FITTING OR HOW DO YOU DO IT? THANK YOU
guest
04-13-2005 17:25:14
 Re: AUX HYDRULICS in reply to PJ LONGHORN, 04-12-2005 17:24:35
The test port on the bottom of the hydraulic unit needs to have an adaptor made that screws
into the threads (3/8"?) and converts to a
hose fitting that will drive the UP force on the
attachment.
Don't expect to drive a down cylinder off the same port or there will not be a way to dumpthe UP cylinder.
Of coarse you should chain down the lift arms
when you want to use the aux.
I find my Suder FEL works pretty fast with the
set up.
I also have a dump va;ve so that I can lower the FEL quickly.
What do you want to drive with the hygraulics?
guest
04-13-2005 17:23:45
attachment.
set up.
Ultradog MN
04-12-2005 17:48:32
The bottom right side plug that you mention is called the test port. I think it is a 1/2"-20 thread. Good luck in finding a fitting unless you are handy and can drill out a bolt. The hydraulics on the N series Fords are lame. Really only made to lift the 3 point. Yes you can tap in to the test port to run an auxilary item like a loader. You have to chain down the 3 point to divert the oil to the test port. I saw an 8N with a loader that was raised off the internal hydraulics. It was sloow to raise the bucket but it did work.
Good luck
Jerry
JMS/MN
04-13-2005 17:35:44
 Re: AUX HYDRULICS in reply to Ultradog MN, 04-12-2005 17:48:32
Jerry- know anyone looking for a trip bucket loader for an 8N?
ZANE
04-12-2005 17:43:43
The last 8N was the 1952 model??? The 1953 Ford tractor was an NAA series.
See the link below for information on installing live hydraulics on the N Ford tractors.
