Order Ford 8N Parts Online
1952 8n starts and idles but loses power in pull
w.stewart
04-14-2005 07:38:20
starts right up and runs good for little while,
then after 10 minutes or so it starts to spit ,sputter and sometimes backfires..recently tuned up (or so said seller) looks to have new plugs,wires, dist cap ..etc..any ideas ?
Dell (WA)
04-14-2005 08:09:54
 Re: 1952 8n starts and idles but loses power in in reply to w.stewart, 04-14-2005 07:38:20
Stewart..... ...yep, classic timeframe for gunked-up ignition SWITCH to heat-up and reduce yer sparkies and cause the engine to back-fire and quit. Will restart after about 1/2hr cool-off. Unfortunately, the N-Ignitionswitch is not as robust as we'd like'm to be. I replace mine 3-times in one summer and then I got gryped and gotta a waterproof 25A marine grade toggle switch. Keys, eh? who need'em?..... ..Dell
Dan Kelly
04-14-2005 14:02:28
 Re: 1952 8n starts and idles but loses power in in reply to Dell (WA), 04-14-2005 08:09:54
Dell,
Keys are also a safty item,
I have a 9 year old at home and would not like to think he could just jump on and hit a button and away he goes. Take out a key; no worrys
thexpostman
04-15-2005 20:16:24
 Re: 1952 8n starts and idles but loses power in in reply to Dan Kelly, 04-14-2005 14:02:28
If you have children or grandchildren you should teach them to stay away from power equipment. Hard to do , yes, impossible NO!
Upper Peninsula, Mi
04-14-2005 16:40:06
For the benefit of your tractor and as a safety item, I would hope you shut the gas off each time your done with the tractor. I had a breakin several years ago where my 9N is stored and they attempted to start the tractor after finding the keys inside camp. It wouldn't start because the gas was shut off. State police said I was lucky they couldn't start the tractor because when they do start a vehicle during a breakin they normally drive it right through the buildings. Safe tractoring. Ron
thexpostman
04-15-2005 20:23:19
 Re: 1952 8n starts and idles but loses power in in reply to Upper Peninsula, Mi, 04-14-2005 16:40:06
9N's must be different from 8N's I always start mine with the valve closed and then open valve. But maybe it's because i need to rebuild the carb. NOT.
Upper Peninsula, Mi
04-16-2005 05:58:45
 Re: 1952 8n starts and idles but loses power in in reply to thexpostman , 04-15-2005 20:23:19
thexpostman, Hi ex. According to the manual there isn't any difference between the 9 and 8 as far as starting. I wonder why do you start it this way and what if any is the advantage? I assume your in the tractor seat when you start it, which is the safe way, then do you get off to open up the gas valve or do you reach down from the seat and open it up? If your tractor is running well after it is started then you turn the gas on, I would think your carb is OK. Just my opinion. Ron
Russ SoCal
04-14-2005 19:51:31
 Martin-Baker for an N??? in reply to Upper Peninsula, Mi, 04-14-2005 16:40:06
Wonder if them folks make a seat could be wired in. ; ^ )
Russ
