Goes in gear only when warm
8ngreenhorn
04-16-2005 10:07:11
Rinsed out my hydro a couple times and now it's filled with fresh oil. I still goes into gear only after it's been running for about ten minutes, then it's okay. By the way, pto is good but lift doesn't budge. Too, is it correct that I have to have the pto running to operate the lift?
souNdguy
04-16-2005 21:36:21
 Re: Goes in gear only when warm in reply to 8ngreenhorn, 04-16-2005 10:07:11
More info.. Pto won't go into gear.. or tranny won't go into gear.
Does it grind.. or just won't budge.
Has 3pt worked before.. but suddenly stopped after the oil change?
Is the control valve moving? linkage attached.. any squirts or swirls in the oil?
Soundguy
Roughstock
04-16-2005 12:05:33
Yes it's true you have to have the PTO turning to use the lift. What kind of oil did you use in the hydro when you changed it and was it going in gear befor the change?
