Oil filter from TSC
ratropia
04-16-2005 14:50:54
I was at my local TSC and ask the MGR. to help me with an oil filter for my 8n. He brought me a fram c3p. It was too tall and I couldn't get the cover back on snug. What is a cross ref. number or part no. for the oil filter other than the FNH part number as today is Saturday and they wont be open tommorow. I could go back to TSC or to WalMart. Thanks Rick T.
Dave 2n
04-17-2005 17:46:14
 Re: Oil filter from TSC in reply to ratropia, 04-16-2005 14:50:54
If it's indeed a C3P, it should work. Sometimes, it takes a little pressure to get it down in the canister. And sometimes, the oil line fitting that comes in from the side near the bottom can be in a little too far and cause the fileter to be difficult to seat.
D Thomas
04-17-2005 11:54:50
I buy mine for an 8N at Tractor Supply and I buy the filter beside the C3P which is just the C3. It works in mine. And yes the book there shows the C3P but it is like you said too tall. Maybe you can take it back and swap it out.
Bush8ter
04-17-2005 09:32:03
Check the cover of the oil canister for a rubber seal; it should match the one that came with the new filter. Peel out the old one and replace it with the new one. The new filter should fit fine.
souNdguy
04-16-2005 21:23:43
I've used fram c3, c3p, Nh filters.. don barkelys' filters, and even napa 1010 filter all with no problems in my 8n and 2n. Check your oil canister for debris in the bottom of it.. perhaps an old rubber seal is at the bottom?
Putting it in right side up?
Soundguy
ratropia
04-17-2005 06:09:37
 Re: Oil filter from TSC in reply to souNdguy, 04-16-2005 21:23:43
Is this rubber washer part No. 6746 in the master parts catalog, part of the canister or an old filter? It is still in the canister along with the spacer. Will it hurt to take it out? Also is it normal to have to loosen the canister to install the filter? With the FNH filter i have never had to, but it was tight fitting it into the canister. Thanks again for all the replies on a "simple" topic.
Rick T.
souNdguy
04-17-2005 13:22:49
 Re: Oil filter from TSC in reply to ratropia, 04-17-2005 06:09:37
The spacer yes.. if you hve extra rubber parts in there. I'd say it cae off a filter. I've seen some filters with no rubber parts.. just metal to metal.. and then I've seen ones with rubebr inserts.. etc.
Sometimes just loosening the bolts on the bracket ( don't have to remove them) gives you the 'jiggle factor' to get a cantankerous filter out.
Soundguy
Don Dever
04-16-2005 20:12:04
Rick, I use Baldwin # P-40, works great, like the others, check the filter, and spring.
Don
RandyR
04-16-2005 15:46:38
Maybe it got switched in the box. I'd take it back and compare it to other C3ps.
ratropia
04-16-2005 16:51:51
 Re: Oil filter from TSC in reply to RandyR, 04-16-2005 15:46:38
The filter itself is stamped c3p. Do you guys suppose the rubber gasket in the canister should be removed? It is shown in the parts catalog. part No. 6746. Also part no. 66735 a spacer, is in the canister. Please advise. Thanks Rick T.
JohnMD
04-16-2005 14:58:51
Fram C3P is the correct filer for an 8N. Check the bottom of the filter canister for an obstruction or mybe you just need to push down harder.
ratropia
04-16-2005 15:10:59
 Re: Oil filter from TSC in reply to JohnMD, 04-16-2005 14:58:51
Thanks for the reply. I couldn't get the filter in without removing the canister bolts and tipping it out some. I did not have to do that with the FNH filter. Also it looks a 1/4 inch or so taller.
Thanks Rick T.
