Rear end ratio
Glenn Winter
03-30-2001 08:28:20
I cannot find what the rear end ratio for a 9-2-8n is.I got the shop,owners manual,i can't find that info anywhe .Thanks Glenn
Dennis 9N/2N
03-30-2001 09:36:34
 Re: Rear end ratio in reply to Glenn Winter, 03-30-2001 08:28:20
I just counted the teeth on my spare 9N/2N differential. The ring gear has 40 teeth, pinion has 6. According to my calculator that is about 6.67:1. However, unlike a car, the transmission always provides some speed reduction. High gear is not a "straight through" coupling, but uses the countershaft, just as first and second do. I am speaking here about the 9N/2N. I do not know the gear ratios of the transmission, but I am sure someone on this board does.
Scott(Ks.)
03-30-2001 10:24:07
 Re: Re: Rear end ratio in reply to Dennis 9N/2N, 03-30-2001 09:36:34
According to the operators manual 1951-52 8N speed@1500rpm
1s't-73.33-1 -- 2.77mph
2n'd-57.04-1 -- 3.56mph
3r'd-41.45-1 -- 4.90mph
4th- 19.86-1 -- 10.23mph
rev.-44.64-1 -- 4.55mph
