Order Ford 8N Parts Online
8N carb.
arky
03-30-2001 14:56:16
ok guys here's the deal.i cleaned the
gas tank on the old redbelly.did'nt even touch the carberator.it was'nt
leaking any gas from the carb before
now it is.all i did was put in a new
sediment bowl screen and gasket in the sediment bowl fixture,as the old
screen was pluged allmost shut.now my
carb is soaking wet with gas all the time.what went haywire?
bj/8N/mt
03-31-2001 07:21:37
 Re: 8N carb. in reply to arky, 03-30-2001 14:56:16
concur with previous comments
also, if the fittings at the sediment bowl aren't tight and leak free the gas will obey the law of gravity and follow the line down to the carb
your mileage will vary
Paul Haas - Pine Island MN
03-30-2001 18:37:24
My guess would be that some tiny little piece of thread sealer or mystery crud found its way into the gas line and is interfering with the seal of the needle/seat. Not too surprising really.
Jerry WI
03-30-2001 15:55:12
Arky, Could it be now that, you have a better flow of fuel to the carb that your float problem surfaced?
It would seem that the time is now to rebuild the carb or at least check the float. Also remember to shut of the fuel and let it "run out of gas" before you park it. Just my thoughts I'm sure others will follow.
Chip Williams
03-31-2001 10:03:42
 Re: Re: 8N carb. in reply to Jerry WI, 03-30-2001 15:55:12
Same problem with my 9N. I need help. Changed the sediment bowl due to bad threads on one connection, now I have gas running out of the air intake of the carb. Assumed a needle and seat problem, rebuilt the carb, set the float correctly, and still have the same problem. With carb bowl off, moving the float up and down shuts off gas as it should. Inspected floats, do not appear to have any gas inside them, nor visible holes, cracks, etc. Put the bowl back on, and turn on the valve on the sediment bowl, and gas runs,(pours) out the air inlet. Any ideas?
Chuck
04-02-2001 09:52:25
 Re: Re: Re: 8N carb. in reply to Chip Williams, 03-31-2001 10:03:42
Gas running all over out of bottom of carb on my 9N. Carb is only 1 year old. I figure a float problem. What is the reason for shutting off fuel supply and running it out of gas when parking tractor???
Chip Williams
04-02-2001 17:43:43
 Re: Re: Re: Re: 8N carb. in reply to Chuck, 04-02-2001 09:52:25
Take a close look. I bet it's running out of the air intake and running down the casting seam on the outside of the bottom bowl and then running off. If not, the only place for gas to leak from the bottom is at the drain plug at the very bottom of the bowl. Chances are it is not the drain plug. Other than that, the bowl is a solid cast part, with nowhere to leak unless cracked. Remove the air intake pipe at the carb, and I expect you'll see that gas is coming out of the carburator air intake.
Chuck
04-03-2001 06:49:52
 Re: Re: Re: Re: Re: 8N carb. in reply to Chip Williams, 04-02-2001 17:43:43
There is a good chance it is leaking from the air intake, I agree, especially if it is flooded?. I did wonder what the little bolt was in the very bottom of the carb, as it appeared that this is where is was leaking from. I tightened this bolt up, but it still dripped. If I am flooded, is this drain bolt a way to drain out and then of course replace bolt and then try to restart?
Chip Williams
04-03-2001 16:12:54
 Re: Re: Re: Re: Re: Re: 8N carb. in reply to Chuck, 04-03-2001 06:49:52
Yes, it would lower the gas level in the bowl, but would not correct the reason for the flooding. As soon as you go again, it will still flood. If you shut off the gas, and let it sit a bit, it should clear up itself without draining the bowl. That's all the plug is, to drain the bowl, but has nothing to do with the reason for the flooding.
