water in oil
philm
04-19-2005 16:02:40
i just drained the oil in my 8n.
i noticed a little water in the drain pan, about a teaspoon, maybe a little more.
it was last changed in september of 2004.
i had run the tractor a few times this past winter to clear snow.
before draining the oil today, i had been running it for about an hour.
i checked the anti-freeze in the radiator, and the coolant is clean.
anyone think i should be concerned about this,
or do you think it is just condensation?
thanks in advance.
souNdguy
04-20-2005 12:13:48
 Re: water in oil in reply to philm, 04-19-2005 16:02:40
If it was emulsified.. I'd be a little concerned.. but if you had clear water.. possibly poole din the low section o fthe plug just setting there.. I'd also agree that it was a bit that had settled and was just waiting for you to drain it..
Soundguy
guest
04-19-2005 16:37:49
just condensation
